Dołączył: 24 Sty 2008 Posty: 22 Skąd jesteś (miejscowość / region): lisburn Posiadane auto: C 220CDI, S280, CL500
Piwa: 1/1
Wysłany: Nie 09 Sie 2015, 23:40
Ukryte opcje w w220
Na panelu od klimy gdy przytrzymamy przycisk 0 i REST pokaza nam sie opcje od 1-99 czy zna ktos ich znaczenie lub moze podeslac linka? Kiedys juz to szukalem i nic nie znalazlem a jezeli temat juz byl poruszany to przepraszam.
Piwa: 1/1
Wysłany: Pią 14 Sie 2015, 13:48
Re: ( Mercedes klasa S ) Ukryte opcje w w220
Znalazlem, ale tylko po angielsku:
0 0 AAC incar temperature sensor (operating module) 30.6 Cº
1 1 Overhead Control panel for incar temperature sensor 30.2 Cº
2 2 Outside temperature sensor 24 Cº
3 3 Left heater exchanger in car temperature sensor 20.6 Cº
4 4 Right heater exchanger in car temperature sensor 12.2 Cº
5 5 Evaporator Core sensor 2.1 Cº
6 6 Engine temperature 88 Cº
7 7 Refrigerant pressure (7.5 BAR Stand-by) 9.5 BAR (AC ON)
8 8 R134A Refrigerant in car temperature sensor 28 Cº
9 L UNTER KÃœMLUNG 9.9 K
10 10 Blower Control voltage 1.8 V
11 SONNE LI VO 22 %
12 SONNE RE VO 39 %
13 SONNE RE HI 42 %
14 SONNE LI HI 13 %
15 15 Average insolation value between 0 and 125% 26 %
16 16 Carbon monoxide value between 0 and 1023 680
17 17 Nitrogen oxide value between 0 and 1023 200
18 18 Dew point temperature 23.5 Cº
19 max UNTER KÃœMLUNG 12.8 K
20 20 Fan output value between 0 and 100% 0 %
21 21 Engine speed 1788 /min
22 22 Ground speed 87 km/h
23 BEL. -DIMMUNG 0 %
24 24 Battery voltage 14.2 V
25
26
27 27 Left hand potentiometer engine speed value between 0 and 100% 100 %
28 28 Centre potentiometer engine speed value between 0 and 100% 0 %
29 29 Right hand potentiometer engine speed value between 0 and 100% 100 %
30 30 Temp of blow air in left rear passenger compartment
31 31 Temp of blow air in left rear passenger compartment
32 32 Temp of evaporator Core in rear passenger Compartment
33 33 Blower voltage in rear passengercompartment
34 34 Specified temperature in left rear passenger compartment
35 35 Specified temperature in right rear passenger compartment
36
37
38 BUILT NR KLA 73
39
40 40 Left hand defroster door value (open/closed plain text at limit stop) ZU
41 41 Right hand defroster door value (open/closed plain text at limit stop) ZU
42 42 Left hand footwell flap value between 0 and 100% ZU
43 43 Right hand footwell flap value between 0 and 100% ZU
44 44 Left hand blend flap value between 0 and 100% AUF
45 45 Right hand blend flap value between 0 and 100% AUF
46 46 Left hand diverter flap 0 and 100% ZU
47 47 Right hand diverter flap value 0 and 100% ZU
48 48 Recirculation door 0 and 100% Frischl.
49 49 AKF bypass flap 0 and 100% AUS
50 50 AAC Software 58
51 51 AAC Hardware 2601
52 52 Software for rear passenger Compartment air Conditioning
53 53 Hardware for rear passenger Compartment air Conditioning
54 54 Software for stepper motor unit 37
55 55. Hardware for stepper motor unit 10
56 56 Software for Centre nozzle 28
57 57 Hardware for Center nozzle 42
58 58 Software for multifunction sensor 19
59 59 Hardware for multifunction sensor 01
60 60 Sofware for daybrightness sensor 32
61 61 Hardware for daybrightness sensor 16
62 REGEL -OFFSET 2 K
63 GEBL. -OFFSET 0.8 V
64
65
66
67
68
69 TUNNEL - MODE Automat.
70 FOLLST. KONTR. Aktiv
71 UL - LOGIK (AKF) Aktiv
72 UL - LOGIK GEN. Inaktiv
73 TUNNEL FUNKTION Aktiv
74 GEBLÄSEBALKEN Generell
75 REHEAT MODUS Inaktiv
76 UMLUFT MANUELL Zeitbegr.
77 DISPLAY Automat.
78 HEISSLAND Inaktiv.
79 MAXCOOL Aktiv.
80 DISPLAY Automat.
81 ABSPEICHERUNG Schlüssel.
82 SCHNELLLAUF Aktiv.
83 UMLUFT 100% Moglich.
84 GEBL. -REAKTION Aktiv.
85 GRUNDEINSTELL Inaktiv.
86 UL-KL. BEI "0" Geschl.
87 GRUNDBELÖFTUNG Aktiv.
88 ESL 20 bar 100% Aktiv.
89 ESL 20 bar 90% Inaktiv.
90 ESL 18 bar 100% Inaktiv.
91 ESL 18 bar 90% Inaktiv.
92 ESL Gndbel. 25% Aktiv.
93 ESL Gndbel. 40% Inaktiv.
94
95
96 Compressor torque (Nm) 9 Nm
97 KOMP STELL 25 %
98 Compressor valve DC current (mA) 270 mA
99 INNER REGLER 26.8 Cº
